ipv6 ospf (for a port)
Configure OSPFv3 on an interface.
Syntax
default ipv6
ospf
default ipv6 ospf
cost
default ipv6 ospf
dead-interval
default ipv6 ospf
enable
default ipv6 ospf
hello-interval
default ipv6 ospf
link-lsa-suppression
default ipv6 ospf nbma-nbr
WORD<0-43>
default ipv6 ospf
poll-interval
default ipv6 ospf
priority
default ipv6 ospf
retransmit-interval
default ipv6 ospf
transit-delay
ipv6 ospf cost
<0-65535>
ipv6 ospf dead-interval
<1-65535>
ipv6 ospf enable
ipv6 ospf hello-interval
<1-65535>
ipv6 ospf nbma-nbr
WORD<0-43> <0-255>
ipv6 ospf nbma-nbr
WORD<0-43> priority <0-255>
ipv6 ospf poll-interval
<0-65535>
ipv6 ospf priority
<0-255>
ipv6 ospf
retransmit-interval <1-1800>
ipv6 ospf transit-delay
<1-1800>
no ipv6 ospf
no ipv6 ospf
enable
no ipv6 ospf
no ipv6 ospf nbma-nbr
WORD<0-43>
Command Parameters
- cost <0-65535>
- Configures the OSPF metric for the
interface. The switch advertises the metric in router link advertisements. The
default is 1.
- dead-interval <1-65535>
- Specifies the dead interval, as
the number of seconds to wait before determining the OSPF router is down. The
default is 40.
- enable
- Enables the OSPF on the IPv6
interface.
- hello-interval <1-65535>
- Specifies the hello interval, in
seconds, for hello packets sent between switches for a virtual interface in an
OSPF area. The default is 10.
- link-lsa-suppression
- Enables link lsa suppression
- nbma-nbr WORD<0-43>
- Configures an NBMA neighbor.
WORD<0-43> specifies the IPv6 address. Use priority <0-255> to change
an existing priority value for an NBMA neighbor. Use <0-255> to assign the
priority value when you create the neighbor.
- poll-interval <0-65535>
- Configures the polling interval
for the OSPF interface in seconds. The default is 120.
- priority <0-255>
- Configures the OSPF priority for
the interface during the election process for the designated router. The interface
with the highest priority number is the designated router. The interface with the
second-highest priority becomes the backup designated router.
- If the priority is 0, the
interface cannot become either the designated router or a backup. The priority is
used only during election of the designated router and backup designated router.
The default is 1.
- retransmit-interval <1-1800>
- Specifies the retransmit interval,
in seconds, for link-state advertisements. The default is 5.
- transit-delay <1-1800>
- Specifies the transit-delay
interval, in seconds, required to transmit a link-state update packet over the
virtual interface. The default is 1.
Command Mode
GigabitEthernet Interface Configuration
